Ir para o conteúdo principal
Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement
O que você precisa
  1. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement, Battery: passo 1, imagem 1 %32
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: passo 2, imagem 1 %32 Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: passo 2, imagem 2 %32
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement, Front and Rear Casing: passo 3, imagem 1 %32 Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement, Front and Rear Casing: passo 3, imagem 2 %32
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: passo 4, imagem 1 %32
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: passo 5, imagem 1 %32
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: passo 6, imagem 1 %32
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: passo 7, imagem 1 %32
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: passo 8, imagem 1 %32
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: passo 9, imagem 1 %32 Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: passo 9, imagem 2 %32
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
Conclusão
Taylor Shields
Membro desde: 10/13/14
846 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 2-1, Benson Fall 2014 Membro de Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 206
