Ir para o conteúdo principal
Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement
O que você precisa
  1. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 2, imagem 1 %32 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 2, imagem 2 %32
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Front and Rear Casing: passo 3, imagem 1 %32 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Front and Rear Casing: passo 3, imagem 2 %32
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 4, imagem 1 %32
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 5, imagem 1 %32
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 6, imagem 1 %32
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 7, imagem 1 %32
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 8, imagem 1 %32
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 9, imagem 1 %32 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 9, imagem 2 %32
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Button Contact Panel: passo 10, imagem 1 %32
    • Carefully wedge the pry tool under the ribbon in the ribbon gate.
    • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
    • Be careful not to damage the ribbon.
  11. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 11, imagem 1 %32
    • Gently press the ribbon back to get access to a Phillips screw behind it.
    • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
  12. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 12, imagem 1 %32 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 12, imagem 2 %32 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 12, imagem 3 %32
    • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
    • Pull the button board away from the rest of the camera.
  13. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, LCD: passo 13, imagem 1 %32
    • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
  14. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 14, imagem 1 %32
    • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
    • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
  15. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 15, imagem 1 %32 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 15, imagem 2 %32
    • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
    • The LCD can now be completely removed from the camera.
  16. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Flash Bulb Assembly: passo 16, imagem 1 %32
    • Arrange camera so it is facing up towards you.
    • Unscrew one .01 inch Phillips screw using a #00 Phillips screwdriver from the front of the camera.
  17. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 17, imagem 1 %32
    • Gently remove the indicated ribbon from respective ribbon gates.
  18. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 18, imagem 1 %32
    • Place spudger under white connector and gently lift it vertically out of its slot.
    • Be careful not to damage wire connector during removal.
  19. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 19, imagem 1 %32
    • Unscrew three .065 inch Phillips screws using a #00 Phillips screwdriver from the back of the camera.
  20. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: passo 20, imagem 1 %32
    • Gently pull away flash bulb assembly from the rest of the camera.
    • Be careful not to damage the ribbon on the rest of the camera.
Conclusão
Taylor Shields
Membro desde: 10/13/14
846 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 2-1, Benson Fall 2014 Membro de Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 265
