Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
Pull the lanyard mount off of the camera using a spudger or your fingers.
Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
Take hold of the inside of the camera, and gently pull away from the back casing.
Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
Uma outra pessoa concluiu este guia.
