Introdução
This guide will provide you with step-by-step instructions on how to replace a faulty LCD screen for a Canon PowerShot SD400. The LCD, or liquid crystal display, is a flat monitor that displays images. The LCD may need to be replaced if it has cracks, discolored pixels, spots, blobs, flickering, or if there's no image signal. Before you begin, ensure that the camera is powered off.
O que você precisa
Locate the 6 screws that you must remove to open the camera housing.
There are 2 screws on the bottom and 2 screws on each side
