Peças
Nenhum componente especificado.
  1. There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws) There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws) There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws)
    • There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws)
  2. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  3. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost.
    • Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost.
  4. Open the case gently. The wrist strap plate and disk pieces will fall out during the process.  The second picture shows what wrist strap plate and disk looks like (The circled parts). Replace the broken camera case with the new one.
    • Open the case gently. The wrist strap plate and disk pieces will fall out during the process. The second picture shows what wrist strap plate and disk looks like (The circled parts).
    • Replace the broken camera case with the new one.
Conclusão
Yi Huang Ke
Membro desde: 18-10-2011
51 Reputation
4 Guias de autoria
James Madison, Team 1-1, Allen Fall 2011 Membro de James Madison, Team 1-1, Allen Fall 2011
JMU-ALLEN-F11S1G1
4 Membros
4 Guias de autoria
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,728
