Ir para o conteúdo principal
Canon PowerShot SD30 Screen Replacement
O que você precisa
  1. Canon PowerShot SD30 Screen Replacement, Front Cover: passo 1, imagem 1 %32 Canon PowerShot SD30 Screen Replacement, Front Cover: passo 1, imagem 2 %32
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Screen Replacement: passo 2, imagem 1 %32
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Screen Replacement, Back Cover: passo 3, imagem 1 %32 Canon PowerShot SD30 Screen Replacement, Back Cover: passo 3, imagem 2 %32 Canon PowerShot SD30 Screen Replacement, Back Cover: passo 3, imagem 3 %32
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Screen Replacement: passo 4, imagem 1 %32
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Screen Replacement, Screen: passo 5, imagem 1 %32 Canon PowerShot SD30 Screen Replacement, Screen: passo 5, imagem 2 %32
    • Remove top button panel by removing the screw located at the top right of the panel.
  6. Canon PowerShot SD30 Screen Replacement: passo 6, imagem 1 %32 Canon PowerShot SD30 Screen Replacement: passo 6, imagem 2 %32
    • Remove screws both at the top and the base of the screen to free the screen.
  7. Canon PowerShot SD30 Screen Replacement: passo 7, imagem 1 %32 Canon PowerShot SD30 Screen Replacement: passo 7, imagem 2 %32 Canon PowerShot SD30 Screen Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to lift the tab that secures the screen wire and remove.
    • You need to do this for both wires.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 155
