Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Screens can be cracked and broken or stop working completely. This guide will show how to replace the screen in the device.
  1. Remove the 2.0 mm Phillips screws on both sides of the camera using the Phillips #00 screwdriver. There will be 4 total screws that need to be removed, 2 on each side. There will be 4 total screws that need to be removed, 2 on each side.
    • Remove the 2.0 mm Phillips screws on both sides of the camera using the Phillips #00 screwdriver.
    • There will be 4 total screws that need to be removed, 2 on each side.
  2. Remove the 4.0 mm Phillips screw located on the bottom of the camera.
    • Remove the 4.0 mm Phillips screw located on the bottom of the camera.
  3. Remove the front face panel of the camera.
    • Remove the front face panel of the camera.
    • The face can be removed by hand with a firm pressure. If one point of the face is stuck to the body, ensure that there is not a screw remaining at that position to hold it in place.
  4. Remove the rear panel of the camera.
    • Remove the rear panel of the camera.
  5. Remove the panel of buttons  by hand.
    • Remove the panel of buttons by hand.
  6. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  7. Remove the 3.0 mm Phillips copper colored screw from the top of the camera.
    • Remove the 3.0 mm Phillips copper colored screw from the top of the camera.
  8. Remove the 3.0 mm Phillips silver screw from the rear face of the camera, located on the upper right corner.
    • Remove the 3.0 mm Phillips silver screw from the rear face of the camera, located on the upper right corner.
  9. Using the plastic spudger, pry the golden film on the front face of the camera off of the microchip.
    • Using the plastic spudger, pry the golden film on the front face of the camera off of the microchip.
    • Once removed, a silver screw will be visible from underneath the golden film.
  10. Remove the 3.0 mm Phillips silver screw using the screwdriver.
    • Remove the 3.0 mm Phillips silver screw using the screwdriver.
  11. Using the metal spudger, carefully pry the small black tab away from the brown film end of the golden film. Once released, the small black tab will point straight away from the front face of the camera.
    • Using the metal spudger, carefully pry the small black tab away from the brown film end of the golden film.
    • Once released, the small black tab will point straight away from the front face of the camera.
    • After releasing the tab, the golden film will no longer be secured to the front face of the camera.
  12. Unplug the small chip from the face of the camera by carefully inserting the metal spudger underneath the cluster of red wires visible. Then lift the cluster of wires upwards, parallel to the front face of the camera.
    • Unplug the small chip from the face of the camera by carefully inserting the metal spudger underneath the cluster of red wires visible. Then lift the cluster of wires upwards, parallel to the front face of the camera.
  13. You can now remove the top panel from the camera using your hands with firm pressure.
    • You can now remove the top panel from the camera using your hands with firm pressure.
  14. Insert the metal spudger underneath the golden film on the front face Lift the golden film on the front face of the camera up and away from its connection
    • Insert the metal spudger underneath the golden film on the front face
    • Lift the golden film on the front face of the camera up and away from its connection
  15. Remove the screen by sliding the golden film out of the channel and pulling the screen away from the camera.
    • Remove the screen by sliding the golden film out of the channel and pulling the screen away from the camera.
Conclusão
3 outras pessoas concluíram este guia.
Braxton Beal
Membro desde: 30/01/2018
672 Reputação
3 Guias de autoria
Equipe
Baylor, Team S1-G3, Johnson Spring 2018 Membro de Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 Membros
4 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 191
