Ir para o conteúdo principal
Canon PowerShot SD1300 IS Lens Replacement
O que você precisa
  1. Canon PowerShot SD1300 IS Lens Replacement, Lens: passo 1, imagem 1 %32 Canon PowerShot SD1300 IS Lens Replacement, Lens: passo 1, imagem 2 %32 Canon PowerShot SD1300 IS Lens Replacement, Lens: passo 1, imagem 3 %32
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
    • Remove a single 2mm J00 screw on the left exterior hidden under the A/V Out port.
  2. Canon PowerShot SD1300 IS Lens Replacement: passo 2, imagem 1 %32
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Lens Replacement: passo 3, imagem 1 %32
    • Use one of your plastic opening tools to separate the screen from the main body of your PowerShot.
  4. Canon PowerShot SD1300 IS Lens Replacement: passo 4, imagem 1 %32
    • Remove five of the 3mm J00 screws under the screen to release the lens for replacement.
    • Lens assembly should be removed through the front of the camera once screws are removed.
Conclusão
Clayton
Membro desde: 03/20/17
560 Reputação
Autoria de 5 guias
Equipe
Texas Tech, Team S13-G1, Bennett Spring 2017 Membro de Texas Tech, Team S13-G1, Bennett Spring 2017
TTU-BENNETT-S17S13G1
Membros da 5
Autoria de 5 guias
Um comentário
I have a SD1300 IS and it has another case screw beneath a plastic cover just below the USB port.
Also step 4 shows 2 screws to remove on the lens that do not go through the metal frame. These should not be removed for lens removal.
It is necessary on mine to remove the 2 screws on the left side of the metal frame that attach to the lens assy.
Greg Reinhart - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 49
Duração total: 1,266
