Introdução
If the shutter button does not work, replacing it can fix the problem. Use this guide to access the shutter button for cleaning or replacement.
O que você precisa
Use the spudger to lift the retaining flap on the Zero Insertion Force (ZIF) tab securing the thick ribbon cable.
Slide out the ribbon cable using fingers or tweezers.
Using tweezers, disconnect the small ribbon cable below the flash assembly from the No Fuss Connector by simply pulling the ribbon cable straight out.
Remove the speaker connector by gripping it with the tool and gently, with a wiggling motion, pull it out.
