Ir para o conteúdo principal
Canon PowerShot SD1200 IS LCD Replacement
O que você precisa
  1. Canon PowerShot SD1200 IS LCD Replacement, Front and Rear Covers: passo 1, imagem 1 %32
    • Remove the battery.
  2. Canon PowerShot SD1200 IS LCD Replacement: passo 2, imagem 1 %32 Canon PowerShot SD1200 IS LCD Replacement: passo 2, imagem 2 %32 Canon PowerShot SD1200 IS LCD Replacement: passo 2, imagem 3 %32
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS LCD Replacement: passo 3, imagem 1 %32 Canon PowerShot SD1200 IS LCD Replacement: passo 3, imagem 2 %32
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS LCD Replacement, LCD: passo 4, imagem 1 %32 Canon PowerShot SD1200 IS LCD Replacement, LCD: passo 4, imagem 2 %32 Canon PowerShot SD1200 IS LCD Replacement, LCD: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the spudger to lift the retaining flap on the Zero Insertion Force (ZIF) tab securing the thick ribbon cable.
    • Slide out the ribbon cable using fingers or tweezers.
    • Be sure you are prying up on the hinged retaining flap, not the connector.
    • Using tweezers, disconnect the small ribbon cable below the flash assembly from the No Fuss Connector by simply pulling the ribbon cable straight out.
  5. Canon PowerShot SD1200 IS LCD Replacement: passo 5, imagem 1 %32 Canon PowerShot SD1200 IS LCD Replacement: passo 5, imagem 2 %32 Canon PowerShot SD1200 IS LCD Replacement: passo 5, imagem 3 %32
    • Remove the L shaped brackets from the left and right side of the LCD screen with the spudger tool.
    • The Brackets have tabs that need to be pried up.
    • Remove the screw below the shutter button. (2.5mm Phillips 00)
    • Holding the sides of the LCD screen, lift the screen up and away to remove.
Conclusão
Uma outra pessoa concluiu este guia.
Jeff Casper
Membro desde: 09/15/16
848 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 17-5, Blackwell Fall 2016 Membro de USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
Membros da 3
Autoria de 7 guias
Um comentário
Hello do you guys sello the LCD screen and do you ship to México.
Killer King - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 25
Duração total: 588
