Ir para o conteúdo principal
Canon PowerShot SD1200 IS Front and Rear Covers Replacement
O que você precisa
  1. Canon PowerShot SD1200 IS Front and Rear Covers Replacement, Front and Rear Covers: passo 1, imagem 1 %32
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Front and Rear Covers Replacement: passo 2, imagem 1 %32 Canon PowerShot SD1200 IS Front and Rear Covers Replacement: passo 2, imagem 2 %32 Canon PowerShot SD1200 IS Front and Rear Covers Replacement: passo 2, imagem 3 %32
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Front and Rear Covers Replacement: passo 3, imagem 1 %32 Canon PowerShot SD1200 IS Front and Rear Covers Replacement: passo 3, imagem 2 %32
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
Conclusão
Jeff Casper
Membro desde: 09/15/16
848 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 17-5, Blackwell Fall 2016 Membro de USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 26
Duração total: 939
