Ir para o conteúdo principal
Canon PowerShot SD1100 IS Top Button Assembly Replacement
O que você precisa
  1. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: passo 1, imagem 1 %32 Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: passo 1, imagem 2 %32
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 2, imagem 1 %32 Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 2, imagem 2 %32 Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 2, imagem 3 %32
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 3, imagem 1 %32 Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 3, imagem 2 %32 Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 3, imagem 3 %32
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 4, imagem 1 %32
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Top Button Assembly: passo 5, imagem 1 %32
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 6, imagem 1 %32
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 7, imagem 1 %32
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 8, imagem 1 %32
    • The shutter button assembly should now be removed.
Conclusão
Uma outra pessoa concluiu este guia.
Wyatt Chan
Membro desde: 01/05/11
235 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-32, Regan Winter 2011 Membro de Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,125
