Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the two 2.9 mm screws from the side panel closest to the camera lens.
Remove the two 2.9 mm screws from the camera bottom panel.
Remove the two 2.9 mm screws from the side panel farthest from the lens.
Pull the back panel away from the camera body, starting at the end with the function buttons.
Remove the small cover panel and the attached wrist strap mount.
Remove the front cover by gently pulling it away from the camera body.
Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
