Ir para o conteúdo principal
Canon PowerShot SD1000 Motherboard Replacement
O que você precisa
  1. Canon PowerShot SD1000 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Canon PowerShot SD1000 Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Motherboard Replacement: passo 4, imagem 1 %32
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Motherboard Replacement, Front Case: passo 6, imagem 1 %32
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Motherboard Replacement: passo 7, imagem 1 %32
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Motherboard Replacement, LCD Screen: passo 8, imagem 1 %32
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 Motherboard Replacement: passo 9, imagem 1 %32 Canon PowerShot SD1000 Motherboard Replacement: passo 9, imagem 2 %32
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 Motherboard Replacement: passo 10, imagem 1 %32
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 Motherboard Replacement: passo 11, imagem 1 %32 Canon PowerShot SD1000 Motherboard Replacement: passo 11, imagem 2 %32
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 Motherboard Replacement: passo 12, imagem 1 %32 Canon PowerShot SD1000 Motherboard Replacement: passo 12, imagem 2 %32 Canon PowerShot SD1000 Motherboard Replacement: passo 12, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
  13. Canon PowerShot SD1000 Motherboard Replacement, Flash Unit: passo 13, imagem 1 %32 Canon PowerShot SD1000 Motherboard Replacement, Flash Unit: passo 13, imagem 2 %32
    • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
  14. Canon PowerShot SD1000 Motherboard Replacement: passo 14, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
  15. Canon PowerShot SD1000 Motherboard Replacement: passo 15, imagem 1 %32
    • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
  16. Canon PowerShot SD1000 Motherboard Replacement: passo 16, imagem 1 %32 Canon PowerShot SD1000 Motherboard Replacement: passo 16, imagem 2 %32
    • Pull the flash assembly forward out of the camera to remove it.
    • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
  17. Canon PowerShot SD1000 Motherboard Replacement, Shutter Button: passo 17, imagem 1 %32 Canon PowerShot SD1000 Motherboard Replacement, Shutter Button: passo 17, imagem 2 %32
    • Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
  18. Canon PowerShot SD1000 Motherboard Replacement, Lens: passo 18, imagem 1 %32
    • Remove the 2.90mm screw from the lens, near the motherboard.
  19. Canon PowerShot SD1000 Motherboard Replacement: passo 19, imagem 1 %32 Canon PowerShot SD1000 Motherboard Replacement: passo 19, imagem 2 %32
    • Using the spudger remove the shutter button by prying the small tab on the front side of the camera.
  20. Canon PowerShot SD1000 Motherboard Replacement: passo 20, imagem 1 %32 Canon PowerShot SD1000 Motherboard Replacement: passo 20, imagem 2 %32
    • With a spudger disconnect the orange connector ribbon as shown.
    • Disconnect the orange connector ribbon that is located under the now removed shutter button.
  21. Canon PowerShot SD1000 Motherboard Replacement: passo 21, imagem 1 %32
    • Remove the two 2.90 mm screws from the motherboard.
  22. Canon PowerShot SD1000 Motherboard Replacement: passo 22, imagem 1 %32
    Comprar
    • With Tweezers detach the bottom orange ribbon.
  23. Canon PowerShot SD1000 Motherboard Replacement: passo 23, imagem 1 %32
    • Remove the screws shown. Start with the outside 6 (3-2.90mm & 3-2.40mm) screws on the metal frame. Then remove the 6 (2.40mm) screws on the back of the lens piece
  24. Canon PowerShot SD1000 Motherboard Replacement: passo 24, imagem 1 %32
    • With spudger gently remove the Viewfinder Window that is directly above the lens.
    Remove screw attaching viewfinder piece to lens framing.
    Adam Biesok - Responder
  25. Canon PowerShot SD1000 Motherboard Replacement: passo 25, imagem 1 %32 Canon PowerShot SD1000 Motherboard Replacement: passo 25, imagem 2 %32 Canon PowerShot SD1000 Motherboard Replacement: passo 25, imagem 3 %32
    • Detach the mother board with lens from body of camera.
    • Carefully remove the lens from the motherboard. Use tweezers to remove any of the 4 connecting ribbons from the lens.
    • Your lens has been removed from the motherboard and bottom framing.
  26. Canon PowerShot SD1000 Motherboard Replacement, Motherboard: passo 26, imagem 1 %32
    • The motherboard (left) is now separated from the lens.
Conclusão
Uma outra pessoa concluiu este guia.
Phillip Phung
Membro desde: 01/19/12
651 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 8-18, Maness Winter 2012 Membro de Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
Membros da 4
Autoria de 12 guias
Um comentário
Which part is the CCD sensor?
yakksoho - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 29
Duração total: 6,681
