O que você precisa
Remove the two 2.9 mm screws from the side panel closest to the camera lens.
Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
With spudger gently remove the Viewfinder Window that is directly above the lens.
Uma outra pessoa concluiu este guia.
