Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Canon PowerShot SD1000 LCD Screen Replacement
O que você precisa
  1. Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: passo 1, imagem 1 %32 Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 LCD Screen Replacement: passo 3, imagem 1 %32
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 LCD Screen Replacement: passo 4, imagem 1 %32
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 LCD Screen Replacement: passo 5, imagem 1 %32
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 LCD Screen Replacement, Front Case: passo 6, imagem 1 %32
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 LCD Screen Replacement: passo 7, imagem 1 %32
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 LCD Screen Replacement, LCD Screen: passo 8, imagem 1 %32
    • Remove the 2 screws located at the top of the LCD panel.
    • Note: These screws are 2.4 mm long.
  9. Canon PowerShot SD1000 LCD Screen Replacement: passo 9, imagem 1 %32 Canon PowerShot SD1000 LCD Screen Replacement: passo 9, imagem 2 %32
    • Pull up the metal frame surrounding LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 LCD Screen Replacement: passo 10, imagem 1 %32
    • Push the metal frame away from the metal tab using the spudger, to detach the frame.
    • Rotate the metal frame upwards.
    • Note: The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 LCD Screen Replacement: passo 11, imagem 1 %32 Canon PowerShot SD1000 LCD Screen Replacement: passo 11, imagem 2 %32
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • Note: BE CAREFUL, both components are attached by an orange connector ribbon and cannot be removed yet!
  12. Canon PowerShot SD1000 LCD Screen Replacement: passo 12, imagem 1 %32 Canon PowerShot SD1000 LCD Screen Replacement: passo 12, imagem 2 %32 Canon PowerShot SD1000 LCD Screen Replacement: passo 12, imagem 3 %32
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Note: Tweezers are helpful to disconnect the ribbon
Conclusão
Phillip Phung
Membro desde: 01/19/12
651 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 8-18, Maness Winter 2012 Membro de Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
Membros da 4
Autoria de 12 guias
Um comentário
Very helpful. These units still sell for a lot more than the cost of the replacement LCD
George Francis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 54
Duração total: 3,538
