Ir para o conteúdo principal
Canon PowerShot SD1000 Front Case Replacement
O que você precisa
  1. Canon PowerShot SD1000 Front Case Replacement, Back Panel: passo 1, imagem 1 %32 Canon PowerShot SD1000 Front Case Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Front Case Replacement: passo 2, imagem 1 %32
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Front Case Replacement: passo 3, imagem 1 %32
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Front Case Replacement: passo 4, imagem 1 %32
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Front Case Replacement: passo 5, imagem 1 %32
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Front Case Replacement, Front Case: passo 6, imagem 1 %32
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Front Case Replacement: passo 7, imagem 1 %32
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Conclusão
Phillip Phung
Membro desde: 01/19/12
651 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 8-18, Maness Winter 2012 Membro de Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 1,360
