Introdução
Use this guide to replace the battery on your Canon PowerShot, model SD1000.
When the battery is starting to fail on your Canon PowerShot it may experience drastically shortened battery life or does not turn on at all. Replacing the faulty battery will remedy the problem and ensure that you are able to continue to use your camera as normal.
This guide will walk you through 4 quick and easy steps on how to change your SD1000 battery (A90mAh 3.7V Lithium-Ion).
O que você precisa
