Ir para o conteúdo principal
Canon PowerShot S80 Motherboard Replacement
O que você precisa
  1. Canon PowerShot S80 Motherboard Replacement, Outer Casing: passo 1, imagem 1 %32 Canon PowerShot S80 Motherboard Replacement, Outer Casing: passo 1, imagem 2 %32
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Motherboard Replacement: passo 2, imagem 1 %32 Canon PowerShot S80 Motherboard Replacement: passo 2, imagem 2 %32
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Motherboard Replacement: passo 3, imagem 1 %32 Canon PowerShot S80 Motherboard Replacement: passo 3, imagem 2 %32 Canon PowerShot S80 Motherboard Replacement: passo 3, imagem 3 %32
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Motherboard Replacement: passo 4, imagem 1 %32 Canon PowerShot S80 Motherboard Replacement: passo 4, imagem 2 %32 Canon PowerShot S80 Motherboard Replacement: passo 4, imagem 3 %32
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Motherboard Replacement, LCD Screen: passo 5, imagem 1 %32
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Motherboard Replacement: passo 6, imagem 1 %32 Canon PowerShot S80 Motherboard Replacement: passo 6, imagem 2 %32
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Motherboard Replacement, Motherboard: passo 7, imagem 1 %32
    • Remove the screws holding down the function set button.
  8. Canon PowerShot S80 Motherboard Replacement: passo 8, imagem 1 %32
    • Gently pry up the tab with a metal spudger and remove the ribbon cable.
  9. Canon PowerShot S80 Motherboard Replacement: passo 9, imagem 1 %32
    • Be mindful of the pins as you lift up and remove the function/set button.
  10. Canon PowerShot S80 Motherboard Replacement: passo 10, imagem 1 %32 Canon PowerShot S80 Motherboard Replacement: passo 10, imagem 2 %32 Canon PowerShot S80 Motherboard Replacement: passo 10, imagem 3 %32
    • Remove the screws from the metal plate.
    • Gently remove the metal plate.
  11. Canon PowerShot S80 Motherboard Replacement: passo 11, imagem 1 %32 Canon PowerShot S80 Motherboard Replacement: passo 11, imagem 2 %32
    • Lift the tab connecting the ribbon cable and detach.
  12. Canon PowerShot S80 Motherboard Replacement: passo 12, imagem 1 %32 Canon PowerShot S80 Motherboard Replacement: passo 12, imagem 2 %32
    • Use a spudger to lift up the ribbon cable tab.
    • Detach the ribbon cable.
  13. Canon PowerShot S80 Motherboard Replacement: passo 13, imagem 1 %32 Canon PowerShot S80 Motherboard Replacement: passo 13, imagem 2 %32
    • Gently remove the entire ribbon cable connection to release the ribbon cable from the camera.
  14. Canon PowerShot S80 Motherboard Replacement: passo 14, imagem 1 %32
    • Unscrew the circuit board from the flash unit.
  15. Canon PowerShot S80 Motherboard Replacement: passo 15, imagem 1 %32 Canon PowerShot S80 Motherboard Replacement: passo 15, imagem 2 %32 Canon PowerShot S80 Motherboard Replacement: passo 15, imagem 3 %32
    • Pry up the ribbon cable connection and remove it from the camera.
    • Lift the ribbon cable tab and completely detach the cable from the camera.
  16. Canon PowerShot S80 Motherboard Replacement: passo 16, imagem 1 %32
    • Pry up the connection, being mindful of the light adhesive.
  17. Canon PowerShot S80 Motherboard Replacement: passo 17, imagem 1 %32
    • Remove the last screw holding the motherboard to the main body.
  18. Canon PowerShot S80 Motherboard Replacement: passo 18, imagem 1 %32 Canon PowerShot S80 Motherboard Replacement: passo 18, imagem 2 %32
    • Use a spudger to gently lift the motherboard from the camera.
Conclusão
BrettH
Membro desde: 10/28/09
219 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 19-5, Maness SU 2012 Membro de Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 Membro
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 4,418
