Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
This guide serves to replace a faulty flash mechanism.
  1. Remove the knot on the wrist lanyard. Remove the battery and memory card.
    • Remove the knot on the wrist lanyard.
    • Remove the battery and memory card.
  2. Remove all screws from the sides of the outer casing. Begin removing the screws on the bottom of the outer casing.
    • Remove all screws from the sides of the outer casing.
    • Begin removing the screws on the bottom of the outer casing.
    • Remove the rest of the screws from the outer casing.
  3. Gently pull the front cover off the camera. Gently pull the front cover off the camera. Gently pull the front cover off the camera.
    • Gently pull the front cover off the camera.
  4. Open the "A/V Out Digital" cover. Remove the screw inside. Gently pull off the back casing. Remove the black "L" shaped piece of metal.
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place. Unplug the wide ribbon cable.
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Remove the L-shaped corner trim containing the picture button.
    • Remove the L-shaped corner trim containing the picture button.
    • Carefully unplug the connection cable that is attached.
  8. Pull the selector wheel from the top corner of the camera. Carefully remove the ribbon cable connection with a set of tweezers.
    • Pull the selector wheel from the top corner of the camera.
    • Carefully remove the ribbon cable connection with a set of tweezers.
  9. With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
    • With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
  10. With a Phillips #00 Screwdriver, unscrew the flash board.
    • With a Phillips #00 Screwdriver, unscrew the flash board.
  11. Remove the cable connection. With a metal spudger, gently pry up.
    • Remove the cable connection. With a metal spudger, gently pry up.
    • Remove the ribon cable. With a metal spudger, gently lift up the black tab.
  12. Lift the flash bulb unit upwards from the camera.
    • Lift the flash bulb unit upwards from the camera.
  13. Lift the entire three-part flash assembly from the camera. Lift the entire three-part flash assembly from the camera.
    • Lift the entire three-part flash assembly from the camera.
Conclusão
BrettH
Membro desde: 28/10/2009
219 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team 19-5, Maness SU 2012 Membro de Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 Membro
5 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 3,526
