Ir para o conteúdo principal
Canon PowerShot S80 Flash Replacement
O que você precisa
  1. Canon PowerShot S80 Flash Replacement, Outer Casing: passo 1, imagem 1 %32 Canon PowerShot S80 Flash Replacement, Outer Casing: passo 1, imagem 2 %32
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Flash Replacement: passo 2, imagem 1 %32 Canon PowerShot S80 Flash Replacement: passo 2, imagem 2 %32
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Flash Replacement: passo 3, imagem 1 %32 Canon PowerShot S80 Flash Replacement: passo 3, imagem 2 %32 Canon PowerShot S80 Flash Replacement: passo 3, imagem 3 %32
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Flash Replacement: passo 4, imagem 1 %32 Canon PowerShot S80 Flash Replacement: passo 4, imagem 2 %32 Canon PowerShot S80 Flash Replacement: passo 4, imagem 3 %32
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Flash Replacement, LCD Screen: passo 5, imagem 1 %32
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Flash Replacement: passo 6, imagem 1 %32 Canon PowerShot S80 Flash Replacement: passo 6, imagem 2 %32
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Flash Replacement, Flash: passo 7, imagem 1 %32
    • Remove the L-shaped corner trim containing the picture button.
    • Carefully unplug the connection cable that is attached.
  8. Canon PowerShot S80 Flash Replacement: passo 8, imagem 1 %32 Canon PowerShot S80 Flash Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Pull the selector wheel from the top corner of the camera.
    • Carefully remove the ribbon cable connection with a set of tweezers.
  9. Canon PowerShot S80 Flash Replacement: passo 9, imagem 1 %32
    • With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
  10. Canon PowerShot S80 Flash Replacement: passo 10, imagem 1 %32
    • With a Phillips #00 Screwdriver, unscrew the flash board.
  11. Canon PowerShot S80 Flash Replacement: passo 11, imagem 1 %32
    • Remove the cable connection. With a metal spudger, gently pry up.
    • Remove the ribon cable. With a metal spudger, gently lift up the black tab.
  12. Canon PowerShot S80 Flash Replacement: passo 12, imagem 1 %32
    • Lift the flash bulb unit upwards from the camera.
  13. Canon PowerShot S80 Flash Replacement: passo 13, imagem 1 %32 Canon PowerShot S80 Flash Replacement: passo 13, imagem 2 %32
    • Lift the entire three-part flash assembly from the camera.
Conclusão
BrettH
Membro desde: 10/28/09
219 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 19-5, Maness SU 2012 Membro de Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 Membro
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 15
Ao todo: 3,710
