Introdução
This guide shows how to clean and remove the zoom lens.
Ferramentas
Peças
Nenhum componente especificado.
Lift off the capture button by wiggling it back and forth while pulling upward.
Be careful not to damage the two clips.
Turn the camera over so that the back is facing you.
Unscrew the three Phillips screws using a #0 Phillips screwdriver.
Lift off the Memory Card casing, sliding the ribbon cable through the camera. Keep pulling until the Memory Card and ribbon cable have been removed from the camera.
Note that the ribbon cable is coming from the external front portion of the camera. Make sure that the ribbon cable will not get caught on anything.
Pick up the zoom lens
Remove the two Phillips screws using a #0 Phillips screwdriver.
Uma outra pessoa concluiu este guia.
