Ir para o conteúdo principal
Canon PowerShot S500 Front and Rear Casing Replacement
O que você precisa
  1. Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : passo 1, imagem 1 %32 Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : passo 1, imagem 2 %32
    • Unscrew five Phillips screws using a #0 Phillips screwdriver.
    • One screw is on upper right corner of the back panel.
    • The other four screws are on the bottom of the camera.
  2. Canon PowerShot S500 Front and Rear Casing  Replacement: passo 2, imagem 1 %32
    • Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Remove the memory card from the slot.
  3. Canon PowerShot S500 Front and Rear Casing  Replacement: passo 3, imagem 1 %32
    • Remove the rear cover from the rest of the camera.
    • This may require gentle rocking of the case to free it.
  4. Canon PowerShot S500 Front and Rear Casing  Replacement: passo 4, imagem 1 %32 Canon PowerShot S500 Front and Rear Casing  Replacement: passo 4, imagem 2 %32
    • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
  5. Canon PowerShot S500 Front and Rear Casing  Replacement: passo 5, imagem 1 %32
    • Free the front cover from the rest of the camera.
    • The cover may require gentle rocking to remove.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Nathan Balcom
Membro desde: 01/21/10
81 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 16-28, Maness Winter 2010 Membro de Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,627
