Ir para o conteúdo principal
Canon PowerShot S410 Battery Replacement
  1. Canon PowerShot S410 Battery Replacement, Battery: passo 1, imagem 1 %32 Canon PowerShot S410 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. Canon PowerShot S410 Battery Replacement: passo 2, imagem 1 %32
    • Pull the orange lever and the battery will spring out slightly.
  3. Canon PowerShot S410 Battery Replacement: passo 3, imagem 1 %32 Canon PowerShot S410 Battery Replacement: passo 3, imagem 2 %32
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
Conclusão
After a new battery has been inserted, close the swinging door and you're done. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Randy Lormand
Membro desde: 01/23/11
349 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 11-27, Maness Winter 2011 Membro de Cal Poly, Team 11-27, Maness Winter 2011
CPSU-MANESS-W11S11G27
4 Membros
Autoria de 7 guias
1Comentário do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 1,775
