Ir para o conteúdo principal
Canon PowerShot S410 Back Cover Replacement
O que você precisa
  1. Canon PowerShot S410 Back Cover Replacement, Battery: passo 1, imagem 1 %32 Canon PowerShot S410 Back Cover Replacement, Battery: passo 1, imagem 2 %32
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. Canon PowerShot S410 Back Cover Replacement: passo 2, imagem 1 %32
    • Pull the orange lever and the battery will spring out slightly.
  3. Canon PowerShot S410 Back Cover Replacement: passo 3, imagem 1 %32 Canon PowerShot S410 Back Cover Replacement: passo 3, imagem 2 %32
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
  4. Canon PowerShot S410 Back Cover Replacement, Back Cover: passo 4, imagem 1 %32
    • Start by laying the camera flat with the LCD screen facing up.
    • Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
  5. Canon PowerShot S410 Back Cover Replacement: passo 5, imagem 1 %32
    • Position the camera with the bottom facing up.
    • Twist the screwdriver counter-clockwise to remove the 4.8mm screw.
    • Repeat to remove the two 2.3mm screws.
  6. Canon PowerShot S410 Back Cover Replacement: passo 6, imagem 1 %32 Canon PowerShot S410 Back Cover Replacement: passo 6, imagem 2 %32
    • Position the camera so that the rubber "AV Out Digital" tab is facing upward.
    • Slide the rubber tab to reveal the bottom screw.
    • Using the screwdriver, remove the two 3.7mm screws.
  7. Canon PowerShot S410 Back Cover Replacement: passo 7, imagem 1 %32
    • Turn the camera with the back side facing you.
    • Grip the edges of the back plate, and carefully slide it off.
    • If there is any resistance in movement, double check there are no screws left in the chassis.
Conclusão
Randy Lormand
Membro desde: 01/23/11
349 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 11-27, Maness Winter 2011 Membro de Cal Poly, Team 11-27, Maness Winter 2011
CPSU-MANESS-W11S11G27
4 Membros
Autoria de 7 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 1,142
