Ir para o conteúdo principal
Canon PowerShot S400 Shutter Button Assembly Replacement
O que você precisa
  1. Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: passo 1, imagem 1 %32 Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: passo 1, imagem 2 %32
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Canon PowerShot S400 Shutter Button Assembly Replacement: passo 2, imagem 1 %32 Canon PowerShot S400 Shutter Button Assembly Replacement: passo 2, imagem 2 %32 Canon PowerShot S400 Shutter Button Assembly Replacement: passo 2, imagem 3 %32
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. Canon PowerShot S400 Shutter Button Assembly Replacement: passo 3, imagem 1 %32 Canon PowerShot S400 Shutter Button Assembly Replacement: passo 3, imagem 2 %32 Canon PowerShot S400 Shutter Button Assembly Replacement: passo 3, imagem 3 %32
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  4. Canon PowerShot S400 Shutter Button Assembly Replacement: passo 4, imagem 1 %32
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
Conclusão
Ross Bryan
Membro desde: 01/21/11
375 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 5-19, Amido Winter 2011 Membro de Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 2,846
