Ir para o conteúdo principal
Canon PowerShot S400 Motherboard Replacement
O que você precisa
  1. Canon PowerShot S400 Motherboard Replacement, LCD Screen: passo 1, imagem 1 %32 Canon PowerShot S400 Motherboard Replacement, LCD Screen: passo 1, imagem 2 %32
    • Unless stated otherwise, use a Phillips #00 screwdriver to remove all screws.
    • On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
    • Remove the four 4.75 mm screws that sit at the bottom of the camera.
  2. Canon PowerShot S400 Motherboard Replacement: passo 2, imagem 1 %32
    • On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
  3. Canon PowerShot S400 Motherboard Replacement: passo 3, imagem 1 %32 Canon PowerShot S400 Motherboard Replacement: passo 3, imagem 2 %32 Canon PowerShot S400 Motherboard Replacement: passo 3, imagem 3 %32
    • On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
    • Remove the two small metal plates, which the four screws hold in place.
  4. Canon PowerShot S400 Motherboard Replacement: passo 4, imagem 1 %32 Canon PowerShot S400 Motherboard Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • When removing the casing, do not drop the small black plastic piece. This piece sits in a small gap above the lens, to the left of the flash, and underneath the camera case.
    • Remove the small black plastic piece and set it aside. If necessary, use tweezers to remove the small black plastic piece.
    • Detach the front case and back case.
  5. Canon PowerShot S400 Motherboard Replacement: passo 5, imagem 1 %32
    • Do not remove the metal plate this step refers to. Removal at this step may damage the ribbon cable. Wait until the next step to remove the plate.
    • Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
    • Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
    • In the image, we have already removed some of the screws.
  6. Canon PowerShot S400 Motherboard Replacement: passo 6, imagem 1 %32 Canon PowerShot S400 Motherboard Replacement: passo 6, imagem 2 %32 Canon PowerShot S400 Motherboard Replacement: passo 6, imagem 3 %32
    • A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
    • Gently release the black latch.
    • Remove the ribbon cable and metal plate assembly.
  7. Canon PowerShot S400 Motherboard Replacement: passo 7, imagem 1 %32 Canon PowerShot S400 Motherboard Replacement: passo 7, imagem 2 %32
    • On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
    • Remove the second 3.5 mm screw that sits directly above the LCD screen.
    • Gently detach the ribbon cable.
  8. Canon PowerShot S400 Motherboard Replacement: passo 8, imagem 1 %32
    • Locate the ribbon cable on the main circuit board, which sits below the lens.
    • Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
  9. Canon PowerShot S400 Motherboard Replacement: passo 9, imagem 1 %32 Canon PowerShot S400 Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the LCD screen and set it aside.
  10. Canon PowerShot S400 Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • On the main circuit board, gently release the black latches of the four ribbon cables.
    • Gently detach the ribbon cables.
  11. Canon PowerShot S400 Motherboard Replacement: passo 11, imagem 1 %32 Canon PowerShot S400 Motherboard Replacement: passo 11, imagem 2 %32
    • Detach the white-capped and green-capped wires, which sit near the flash.
  12. Canon PowerShot S400 Motherboard Replacement: passo 12, imagem 1 %32
    • Using a spudger, gently detach the shutter button assembly from the camera.
  13. Canon PowerShot S400 Motherboard Replacement: passo 13, imagem 1 %32
    • Remove the four 3.5 mm screws that hold the main circuit board.
    • Do not remove the main circuit board yet.
  14. Canon PowerShot S400 Motherboard Replacement: passo 14, imagem 1 %32 Canon PowerShot S400 Motherboard Replacement: passo 14, imagem 2 %32
    • Do not completely remove the main circuit board from the camera. A soldered ribbon cable still attaches the board to the camera. Complete removal would break the soldering points.
    • In a hinge-like motion, gently lift the bottom of the main circuit board, which is the side without the soldering points.
    • Gently detach the white ribbon cable from the underside of the main circuit board.
  15. Canon PowerShot S400 Motherboard Replacement: passo 15, imagem 1 %32 Canon PowerShot S400 Motherboard Replacement: passo 15, imagem 2 %32
    • Do not attempt this next step unless you have soldering experience and feel comfortable desoldering. Otherwise you may damage the camera.
    • Gently desolder the two ribbon cables attached to the motherboard.
    • Remove the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Ross Bryan
Membro desde: 01/21/11
374 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 5-19, Amido Winter 2011 Membro de Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 22
Ao todo: 3,031
