Introdução
This guide illustrates how to replace the motherboard in the S400.
O que você precisa
On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
Remove the four 4.75 mm screws that sit at the bottom of the camera.
On the main circuit board, gently release the black latches of the four ribbon cables.
Gently detach the ribbon cables.
