Introdução
This guide will show you how to remove the front and back casing of the camera.
O que você precisa
On the bottom of the camera, use your thumb to press the rubber battery cover towards the side of the camera with the strap base. The cover will shift to extend beyond the rest of the camera.
Locate the sliding button labeled "CF open" on the back of the camera.
Press and slide down the button labeled "CF open". The memory card cover will pop open.
