Ir para o conteúdo principal
Canon PowerShot S100 Top Panel Replacement
O que você precisa
  1. Canon PowerShot S100 Top Panel Replacement, Outer Case: passo 1, imagem 1 %32 Canon PowerShot S100 Top Panel Replacement, Outer Case: passo 1, imagem 2 %32 Canon PowerShot S100 Top Panel Replacement, Outer Case: passo 1, imagem 3 %32
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Top Panel Replacement: passo 2, imagem 1 %32
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Top Panel Replacement: passo 3, imagem 1 %32 Canon PowerShot S100 Top Panel Replacement: passo 3, imagem 2 %32 Canon PowerShot S100 Top Panel Replacement: passo 3, imagem 3 %32
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
  4. Canon PowerShot S100 Top Panel Replacement, Top Panel: passo 4, imagem 1 %32
    • Turn the camera over on its side so that the terminals are facing you.
    • Remove the screw (3.9mm, Phillips #00) that is connecting the top panel to the metal frame.
  5. Canon PowerShot S100 Top Panel Replacement: passo 5, imagem 1 %32 Canon PowerShot S100 Top Panel Replacement: passo 5, imagem 2 %32
    • Remove the screw (2.9mm, Phillips #00) that is directly above the camera lens.
  6. Canon PowerShot S100 Top Panel Replacement: passo 6, imagem 1 %32 Canon PowerShot S100 Top Panel Replacement: passo 6, imagem 2 %32
    • Using the spudger, remove the center ribbon cable that is connecting the top panel to the motherboard.
    • Gently lift the top panel off the camera.
    • Tweezers may also be used to remove the ribbon cable.
Conclusão
3 outras pessoas executaram este guia.
Ricky
Membro desde: 02/23/15
958 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-4, Leahy Winter 2015 Membro de USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 2,108
