Introdução
Removing the body cover is necessary to access other parts inside the camera.
O que você precisa
Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
Uma outra pessoa concluiu este guia.
