Ir para o conteúdo principal
Canon PowerShot G9 SD-Card Slot Write Lock.
O que você precisa
  1. Canon PowerShot G9 SD-Card Slot Write Lock., Open rear cover of camera.: passo 1, imagem 1 %32 Canon PowerShot G9 SD-Card Slot Write Lock., Open rear cover of camera.: passo 1, imagem 2 %32
    • Be very careful not to touch any charged flash capacitor
    • Remove screws as marked. 2 for strap holder, 5 for back cover
    • Remove Back cover and strap holder
  2. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Buttons.: passo 2, imagem 1 %32 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Buttons.: passo 2, imagem 2 %32
    • Remove the two screws circled green.
    • Remove the buttons.
  3. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: passo 3, imagem 1 %32 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: passo 3, imagem 2 %32 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: passo 3, imagem 3 %32
    • Disconnect ribbon cable by lifting up flap.
    • Disconnect other cable (another flap)
    • Remove jog dial unit
  4. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Finder dial.: passo 4, imagem 1 %32 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Finder dial.: passo 4, imagem 2 %32
    • Remove the one screw circled green.
    • Remove the finder dial
  5. Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: passo 5, imagem 1 %32 Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: passo 5, imagem 2 %32 Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: passo 5, imagem 3 %32
    • Remove screw and lift LCD upwards very carefully. Do not put any strain on cables.
    • Carefully remove flex cables. The left has a flap that needs to be opened (up), the right just needs to be pulled out. Be careful when re-inserting the right one, you can easily damage the fragile cable.
    • Remove the LCD
  6. Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: passo 6, imagem 1 %32 Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: passo 6, imagem 2 %32 Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: passo 6, imagem 3 %32
    • Remove screws.
    • Disconnect connectors for Lens assembly
    • Carefully disconnect the tiny cable
    • Next step is removing the PCB. I made the mistake not to take care about the battery compartment switch. If you are not careful, the black lever will break off. Not a problem though, because then the camera will work also with opened battery compartmen
    • Remove main PCB by slightly bending outward the cover for the jack with fingernail. Now lift the PCB slightly upwards.
    • Look under the PCB, there is a connector that needs to be separated by means of a small screwdriver or spudger.
    • Re-attaching the connector is not easy. I used a small screwdriver to carefully press the connector back in place.
    • This is not the official method to do this. Normally the Top cover and several other parts need to be removed too.
  7. Canon PowerShot G9 SD-Card Slot Write Lock., Check SD-Card Slot.: passo 7, imagem 1 %32 Canon PowerShot G9 SD-Card Slot Write Lock., Check SD-Card Slot.: passo 7, imagem 2 %32
    • Measure continuity with a multimeter on SD-card slot write protect switch.
    • If it is not working, short the two points with a bodge wire, so write lock is disabled
    • Another possible fault is a broken soldering joint holding the case of the SD-card reader in place.
Conclusão
Repeat the steps in order to reassemble your device.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Thomas Widmaier
Membro desde: 03/05/13
2.039 Reputação
Autoria de 10 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.506 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 1,028
