Ir para o conteúdo principal
Canon PowerShot G7X Lens Replacement
O que você precisa
  1. Canon PowerShot G7X Lens Replacement, Dial: passo 1, imagem 1 %32
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Lens Replacement: passo 2, imagem 1 %32
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Lens Replacement: passo 3, imagem 1 %32
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Lens Replacement: passo 4, imagem 1 %32
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Lens Replacement: passo 5, imagem 1 %32
    • Remove the back plate.
  6. Canon PowerShot G7X Lens Replacement: passo 6, imagem 1 %32
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Lens Replacement: passo 7, imagem 1 %32 Canon PowerShot G7X Lens Replacement: passo 7, imagem 2 %32
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
  8. Canon PowerShot G7X Lens Replacement, Flash: passo 8, imagem 1 %32 Canon PowerShot G7X Lens Replacement, Flash: passo 8, imagem 2 %32
    • Remove the three, blue 5 mm Phillips screws from the back plate.
    • Remove seven 2 mm Phillips #000 screws.
  9. Canon PowerShot G7X Lens Replacement: passo 9, imagem 1 %32 Canon PowerShot G7X Lens Replacement: passo 9, imagem 2 %32
    • While using the plastic opening tool, gently pry the top plate off the camera.
  10. Canon PowerShot G7X Lens Replacement: passo 10, imagem 1 %32 Canon PowerShot G7X Lens Replacement: passo 10, imagem 2 %32
    • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
  11. Canon PowerShot G7X Lens Replacement: passo 11, imagem 1 %32 Canon PowerShot G7X Lens Replacement: passo 11, imagem 2 %32
    • Remove the 2 mm Phillips #000 screw underneath the top plate.
    • Remove silver plate.
  12. Canon PowerShot G7X Lens Replacement: passo 12, imagem 1 %32
    • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
  13. Canon PowerShot G7X Lens Replacement: passo 13, imagem 1 %32 Canon PowerShot G7X Lens Replacement: passo 13, imagem 2 %32
    • Using the spudger, gently lift the ribbon cable from underneath the front plate.
    • Remove the front plate.
  14. Canon PowerShot G7X Lens Replacement: passo 14, imagem 1 %32 Canon PowerShot G7X Lens Replacement: passo 14, imagem 2 %32
    • Remove flash toggle plate.
    • Remove the 2mm Phillips #000 screws under the flash toggle.
  15. Canon PowerShot G7X Lens Replacement: passo 15, imagem 1 %32 Canon PowerShot G7X Lens Replacement: passo 15, imagem 2 %32
    • Flash contains charged capacitor. Shock hazard.
    • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
  16. Canon PowerShot G7X Lens Replacement, Lens: passo 16, imagem 1 %32
    • Remove the 5 mm Phillips #000 screw from the copper plate.
  17. Canon PowerShot G7X Lens Replacement: passo 17, imagem 1 %32
    • Using the black nylon spudger, lift the ribbon cable gently until it comes out.
  18. Canon PowerShot G7X Lens Replacement: passo 18, imagem 1 %32
    • Remove the copper plate to reveal connections to the lens.
  19. Canon PowerShot G7X Lens Replacement: passo 19, imagem 1 %32
    • Using the black nylon spudger, lift gently on the pin connector until it comes off.
  20. Canon PowerShot G7X Lens Replacement: passo 20, imagem 1 %32 Canon PowerShot G7X Lens Replacement: passo 20, imagem 2 %32
    • Using the spudger, gently lift on the ribbon cable until it comes out.
    • Separate the lens from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
3 comentários
Not that great of step by step. Lots of missed steps and lots different screw length and thread. Over all it's just an ok guide.
Nick Thomas - Responder
how do you tell if the lens is CCD or not
kingwayne77none - Responder
Poor instructions indeed. At step 11 silver plate still stuck. More screws than indicated.
Hugo Lyppens - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 61
Duração total: 6,584
