Introdução
This guide will help you replace the flash for your camera. Caution should be used because a capacitor is attached to the flash which may cause harm if handled carelessly.
O que você precisa
Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
Remove the three, blue 5 mm Phillips screws from the back plate.
Remove seven 2 mm Phillips #000 screws.
Quase terminado!
Conclusão
