Ir para o conteúdo principal
Canon PowerShot G7X Dial Replacement
O que você precisa
  1. Canon PowerShot G7X Dial Replacement, Dial: passo 1, imagem 1 %32
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Dial Replacement: passo 2, imagem 1 %32
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Dial Replacement: passo 3, imagem 1 %32
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Dial Replacement: passo 4, imagem 1 %32
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Dial Replacement: passo 5, imagem 1 %32
    • Remove the back plate.
  6. Canon PowerShot G7X Dial Replacement: passo 6, imagem 1 %32
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Dial Replacement: passo 7, imagem 1 %32 Canon PowerShot G7X Dial Replacement: passo 7, imagem 2 %32
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 519
