Ir para o conteúdo principal
Canon PowerShot G3 Speaker Replacement
O que você precisa
  1. Canon PowerShot G3 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Start to remove the screws around the camera: from the front, back, sides, and bottom.
  2. Canon PowerShot G3 Speaker Replacement: passo 2, imagem 1 %32
    • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
  3. Canon PowerShot G3 Speaker Replacement: passo 3, imagem 1 %32
    • Next remove the front and right side panels (the left is attached to the front panel).
  4. Canon PowerShot G3 Speaker Replacement: passo 4, imagem 1 %32
    • Finally, remove the top panel as shown.
  5. Canon PowerShot G3 Speaker Replacement: passo 5, imagem 1 %32 Canon PowerShot G3 Speaker Replacement: passo 5, imagem 2 %32
    • The front of the camera should now resemble the picture shown. (Image 1)
    • Remove the capacitor/speaker housing using your finger nail or other thin object to lift it up around the edges. (Image 2)
  6. Canon PowerShot G3 Speaker Replacement: passo 6, imagem 1 %32
    • To remove the circuit ribbon (brown strip) pull it out of the plastic piece it is connected to.
  7. Canon PowerShot G3 Speaker Replacement: passo 7, imagem 1 %32
    • You should now be able to see how the capacitor/speaker housing slides out of the frame.
  8. Canon PowerShot G3 Speaker Replacement: passo 8, imagem 1 %32 Canon PowerShot G3 Speaker Replacement: passo 8, imagem 2 %32
    • Disconnect the speaker wires from the camera, then use a small flat head screw driver to lift the speaker out of its housing.
    • Order a new speaker from the manufacturer or take it to a local electronics store to see if they have one.
Conclusão
Ryan Riales
Membro desde: 10/22/15
201 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 260
