Ir para o conteúdo principal
Canon PowerShot G12 HDMI Port Replacement
O que você precisa
  1. Canon PowerShot G12 HDMI Port Replacement, HDMI Port: passo 1, imagem 1 %32
  2. Canon PowerShot G12 HDMI Port Replacement: passo 2, imagem 1 %32
    • On the right side of the camera looking from the back, locate the HDMI port and use a spudger to remove it.
    On my G12, I also needed to remove the front cover of the camera before being able to remove the HDMI cover
    jnbruin - Responder
  3. Canon PowerShot G12 HDMI Port Replacement: passo 3, imagem 1 %32
    • Insert the new HDMI port until you hear a click on both sides, ensuring the holes match up with the ports on the camera.
Conclusão
Equipe
USF Tampa, Team 1-5, Leahy Winter 2015 Membro de USF Tampa, Team 1-5, Leahy Winter 2015
USFT-LEAHY-W15S1G5
3 Membros
Autoria de 6 guias
1Comentário do guia
The title of this guide suggests it gives instructions on replacing the HDMI port. In fact, it is a guide for the replacement of the HDMI port cover only.
jnbruin - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 2,387
