Ir para o conteúdo principal
Canon PowerShot G11 Rear Cover Replacement
O que você precisa
  1. Canon PowerShot G11 Rear Cover Replacement, Rear Cover: passo 1, imagem 1 %32
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
  2. Canon PowerShot G11 Rear Cover Replacement: passo 2, imagem 1 %32
    • Remove the four screws on the left side of the camera.
  3. Canon PowerShot G11 Rear Cover Replacement: passo 3, imagem 1 %32
    • Remove the screw on the right side of the camera.
  4. Canon PowerShot G11 Rear Cover Replacement: passo 4, imagem 1 %32
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
  5. Canon PowerShot G11 Rear Cover Replacement: passo 5, imagem 1 %32
    • Remove the screw to the right of the view finder on the rear of the camera.
  6. Canon PowerShot G11 Rear Cover Replacement: passo 6, imagem 1 %32
    • Use the spudger to crack open the case.
  7. Canon PowerShot G11 Rear Cover Replacement: passo 7, imagem 1 %32
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
  8. Canon PowerShot G11 Rear Cover Replacement: passo 8, imagem 1 %32
    • The rear cover is now unattached from the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Dustin Brinegar
Membro desde: 01/21/15
688 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 5-6, Brown Winter 2015 Membro de USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 1,068
