Introdução
Before starting this guide it is important to know that the screwdriver used on each screw is a Phillips #00 screwdriver. It is imperative to keep track of every screw, and to know where each screw was located.
O que você precisa
To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
Remove the two screws above the buttons followed by the screw on the bottom, using a Phillips #00 screwdriver.
Remove the two screws on the front casing using a Phillips #00 screwdriver.
