Introdução
Be careful when removing each screw on this camera. Each screw has a specific location and they are different sizes. The best way to make sure that you do not lose or misplace any screws is by making a list of what screws you take out and where it was located.
O que você precisa
To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
Remove the two screws above the buttons followed by the screw on the bottom, using a Phillips #00 screwdriver.
