Ir para o conteúdo principal
Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement
O que você precisa
  1. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: passo 1, imagem 1 %32 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: passo 1, imagem 2 %32
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right to open it.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: passo 2, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the screws.
  3. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: passo 3, imagem 1 %32
    • Remove the two 4.0mm screws on the bottom of the camera located near the battery door using a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: passo 4, imagem 1 %32
    • At the bottom of the camera next to the battery door, remove two more screws using the Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: passo 5, imagem 1 %32
    • To remove the back portion of the camera case, use your fingers to carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: passo 6, imagem 1 %32 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: passo 6, imagem 2 %32
    • On the motherboard there should be a white port. Using the spudger, disconnect it from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: passo 7, imagem 1 %32
    • Follow the green and white wire. There is a gray piece of rubber holding the button into place. Remove it with the spudger.
  8. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: passo 8, imagem 1 %32
    • Lift the panel off from the top of the camera with your hands.
Conclusão
Michelle Ngo
Membro desde: 07/23/19
595 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S1-G3, Liner Summer 2019 Membro de UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 319
