Ir para o conteúdo principal
Canon PowerShot ELPH330 HS Camera Case Replacement
O que você precisa
  1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: passo 1, imagem 1 %32 Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: passo 1, imagem 2 %32
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right which will then open the door.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Case Replacement: passo 2, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the two screws.
  3. Canon PowerShot ELPH330 HS Camera Case Replacement: passo 3, imagem 1 %32
    • Remove two more screws using the Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Case Replacement: passo 4, imagem 1 %32
    • On the lower right side of the camera case, remove the single screw using Phillips #00 screwdriver.
    • On the upper right side of the camera, remove the HDMI A/V out port.
    • Beneath the port cover, remove the screw using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Case Replacement: passo 5, imagem 1 %32
    • Using your fingers, carefully pry the case apart at the seam.
Conclusão
Michelle Ngo
Membro desde: 07/23/19
595 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S1-G3, Liner Summer 2019 Membro de UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 193
