Ir para o conteúdo principal
Canon PowerShot ELPH330 HS Camera Repair LCD Screen Replacement
O que você precisa
  1. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: passo 1, imagem 1 %32 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: passo 1, imagem 2 %32
    • Turn off your camera.
    • Remove the battery.
    • Slide the battery door open with the rubber pad on the bottom right side of the camera.
    • Remove the battery by pushing down on the release button.
  2. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: passo 2, imagem 1 %32
    • Remove the two screws on the left side with a Phillips #00 screwdriver.
  3. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: passo 3, imagem 1 %32
    • Remove the two screws on the bottom of the camera with a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: passo 4, imagem 1 %32
    • Remove the two screws on the right side with a Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: passo 5, imagem 1 %32
    • Using your fingers, carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: passo 6, imagem 1 %32 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: passo 6, imagem 2 %32
    • Flip the camera over so that the lens is facing you.
    • Disconnect the highlighted port from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: passo 7, imagem 1 %32 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: passo 7, imagem 2 %32
    • Remove the bracket around the LCD screen.
  8. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: passo 8, imagem 1 %32
    • Using the spudger, carefully pry the top to remove the LCD screen.
Conclusão
Michelle Ngo
Membro desde: 07/23/19
595 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S1-G3, Liner Summer 2019 Membro de UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 492
