Ir para o conteúdo principal
Canon PowerShot ELPH 150 IS Battery Replacement
  1. Canon PowerShot ELPH 150 IS Battery Replacement, Battery: passo 1, imagem 1 %32 Canon PowerShot ELPH 150 IS Battery Replacement, Battery: passo 1, imagem 2 %32
    • Safety First: Power off your device. Locate the On/Off button.
  2. Canon PowerShot ELPH 150 IS Battery Replacement: passo 2, imagem 1 %32
    • Hold button down firmly until the screen goes dark and the camera is powered off.
  3. Canon PowerShot ELPH 150 IS Battery Replacement: passo 3, imagem 1 %32
    • Locate the Battery door which is marked, "CARD/BATT OPEN"
  4. Canon PowerShot ELPH 150 IS Battery Replacement: passo 4, imagem 1 %32
    • Press the door down with your thumb and slide to the right until you hear a click. This means the door has unlocked and will open.
  5. Canon PowerShot ELPH 150 IS Battery Replacement: passo 5, imagem 1 %32
    • With the door open, locate the orange clip near the edge of the camera. This clip is holding the battery in place.
  6. Canon PowerShot ELPH 150 IS Battery Replacement: passo 6, imagem 1 %32
    • Press the orange clip back towards the back plate to release the battery.
  7. Canon PowerShot ELPH 150 IS Battery Replacement: passo 7, imagem 1 %32
    • The battery should pop out easily and you can simply remove the battery from its housing.
Conclusão
Uma outra pessoa concluiu este guia.
Morgan Forester
Membro desde: 03/21/17
284 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 487
