Introdução
The Canon PowerShot D20 is waterproof and shockproof, so it won't suffer from a cracked LCD screen. However, if the camera is improperly sealed, water damage may prevent the screen from working. In this case, make sure the camera still works by taking a few pictures and uploading them to your computer, then replace the screen.
O que você precisa
Open the cover on the bottom of the camera.
Remove the battery.
Remove the memory card.
Ferramenta utilizada neste passo:Tweezers$4.99
Gently disconnect the two ribbon wires from the camera. Use tweezers or a spudger to remove them.
To remove these cables, pull them straight out of their sockets.
When reassembling, be sure you plug these cables into the sockets fully. You will hear a faint click when they are fully in.
Uma outra pessoa concluiu este guia.
2Comentários do guia
How do you take the shutter button part off ?
