Introdução
Have you dropped your Canon Powershot A80 once or twice over the years, and now the cover is a little loose or even coming off, making it hard to hold it steady? Have you thought about using tape (like me) to hold it on?
Great news—this guide is for you (and you won't have to use tape!)
Follow the instructions in this guide to help you remove and replace the front cover of your camera so you can have a better grip when taking photos and don’t have to worry about the cover falling off. You also might use this guide if you need to access the internal components of your camera if you are working on another repair.
Before you begin this repair, be sure that your camera is off and unplugged from the charger. For an additional safety measure, remove the battery before you begin too.
O que você precisa
Using a Phillips #00 screwdriver, remove the 3.3 mm long top screw located on the side of the camera. This screw holds the side panels and the front cover together.
