Ir para o conteúdo principal
Canon PowerShot A80 Back Cover Replacement
O que você precisa
  1. Canon PowerShot A80 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the three Phillips #00 screws from the bottom of the camera.
  2. Canon PowerShot A80 Back Cover Replacement: passo 2, imagem 1 %32 Canon PowerShot A80 Back Cover Replacement: passo 2, imagem 2 %32
    • Open the door to the CompactFlash memory card slot by sliding it towards you and swinging it open.
    • Remove the memory card if it is still in the camera.
    • Use the Phillips #00 screwdriver to remove the single screw underneath the memory card slot door.
  3. Canon PowerShot A80 Back Cover Replacement: passo 3, imagem 1 %32
    • Remove the Phillips #00 screw located inside the top of the memory card compartment.
  4. Canon PowerShot A80 Back Cover Replacement: passo 4, imagem 1 %32 Canon PowerShot A80 Back Cover Replacement: passo 4, imagem 2 %32
    • Open the battery compartment door at the bottom of the camera by sliding the latch to the right and then sliding the door down.
    • Remove the batteries from the compartment.
    • Remove the three Phillips #00 screws located inside the battery compartment.
    • The screw on the left is longer than the other two.
  5. Canon PowerShot A80 Back Cover Replacement: passo 5, imagem 1 %32
    • Remove the top lid of the camera.
    • Be cautious of the fragile mylar cable that connects the lid to the main body of the camera.
    • Removing the lid takes a little force. Do this gently. There may be a snapping sound.
    • The door to the memory card compartment will be freed and should be removable now.
    • In other versions of this camera, there is a tab that secures the top from the wrist strap. If yours has this, you won't be able to completely separate the top until you have removed the top screw in Step 8.
  6. Canon PowerShot A80 Back Cover Replacement: passo 6, imagem 1 %32
    • Remove the two Phillips #00 screws from the side of the camera.
    • Open the small rubber door below this screw that covers the connectors.
  7. Canon PowerShot A80 Back Cover Replacement: passo 7, imagem 1 %32 Canon PowerShot A80 Back Cover Replacement: passo 7, imagem 2 %32
    • Open and pivot the LCD screen to its widest open position.
    • Remove the rear cover by pulling it straight away from the body of the camera.
    • When reassembling the camera, remember to replace the screws in the same location from which you removed them. Otherwise, you may damage the camera.
Conclusão
konrad
Membro desde: 01/11/11
220 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 7-31, Regan Winter 2011 Membro de Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
Membros da 6
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 25
Duração total: 5,367
