Introdução
Use this guide to replace the Canon PowerShot A75's upper motherboard.
O que você precisa
Remove the 4.4mm screw directly behind the eyepiece on the top of the camera.
Remove the 4.3mm screw to the right of the eyepiece housing in the crack in between the eyepiece and a ribbon cable on top of the camera.
Remove the 3.5mm screw found near the capacitor and the flash unit.
Quase terminado!
Conclusão
