Ir para o conteúdo principal
Canon PowerShot A75 Batteries Replacement
  1. Canon PowerShot A75 Batteries Replacement, Batteries: passo 1, imagem 1 %32
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Batteries Replacement: passo 2, imagem 1 %32 Canon PowerShot A75 Batteries Replacement: passo 2, imagem 2 %32 Canon PowerShot A75 Batteries Replacement: passo 2, imagem 3 %32
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Batteries Replacement: passo 3, imagem 1 %32 Canon PowerShot A75 Batteries Replacement: passo 3, imagem 2 %32 Canon PowerShot A75 Batteries Replacement: passo 3, imagem 3 %32
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
Conclusão
Put in fresh batteries. Gently shut the flap and slide it forward until you hear a click.
Equipe
Cal Poly, Team 17-30, Amido Spring 2012 Membro de Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
Membros da 5
Autoria de 12 guias
3 comentários
Hi, there is a problem with my Powershot a75. Whenever I switch it on, it just says change the batteries even though they are either new, or fully charged. Thanks
Harry collier - Responder
had same trouble i fix it buy pressing the print button on back next to the disp button it should work then
hot5 - Responder
Probably you have change backup battery which is rechargeable and not easy to change. It is close to chargeable outlet.
Maganbhai Patel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 36
Duração total: 1,788
