Ir para o conteúdo principal
Canon PowerShot A630 LCD Screen Replacement
O que você precisa
  1. Canon PowerShot A630 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Open the LCD screen of the camera
  2. Canon PowerShot A630 LCD Screen Replacement: passo 2, imagem 1 %32 Canon PowerShot A630 LCD Screen Replacement: passo 2, imagem 2 %32
    • Rotate the screen so that it is perpendicular to the body of the camera
    • Remove the .2mm screw using a Phillips #00 screwdriver
    • Rotate screen 180 degrees and remove second .2mm screw
  3. Canon PowerShot A630 LCD Screen Replacement: passo 3, imagem 1 %32 Canon PowerShot A630 LCD Screen Replacement: passo 3, imagem 2 %32
    • Gently remove the back panel of the LCD screen
  4. Canon PowerShot A630 LCD Screen Replacement: passo 4, imagem 1 %32
    • Once the back panel is removed another .2mm screw will be revealed, remove this screw to remove the front panel of the LCD screen
  5. Canon PowerShot A630 LCD Screen Replacement: passo 5, imagem 1 %32
    • Gently remove front panel of the LCD screen
  6. Canon PowerShot A630 LCD Screen Replacement: passo 6, imagem 1 %32 Canon PowerShot A630 LCD Screen Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Locate the ribbon (orange) and using tweezers gently pull back the retaining clip and pull the ribbon out
  7. Canon PowerShot A630 LCD Screen Replacement: passo 7, imagem 1 %32 Canon PowerShot A630 LCD Screen Replacement: passo 7, imagem 2 %32 Canon PowerShot A630 LCD Screen Replacement: passo 7, imagem 3 %32
    • Use a spudger to gently remove the LCD screen from the metal backing plate
Conclusão
3 outras pessoas executaram este guia.
Kady Rose
Membro desde: 10/13/14
219 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 2-5, Benson Fall 2014 Membro de Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 Membros
Autoria de 18 guias
2Comentários do guia
Where can I purchase a replacement LCD screen?
steigw - Responder
I have the same question!
Regina Villarreal -
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 40
Ao todo: 2,827
